capacitors in parallel
Discussion in 'General Electronics Chat' started by christopher, May 12, 2005.
  1. christopher
    May 12, 2005
    [attachmentid=640] I GOT THIS QUESTION AM STUCK ON PLEASE HELP
    this is for the attachment
    in a pratical circuit with three different capacitors in parallel ( say 10 uF , 100uF and 1uF ) show how, you think, the three currents would change.
    Attacment
    Attacment note
    ( Wher the scales are not linear, as the graph is to show relative currents and time)
    THANKS
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Since capacitance in parallel can be added together, for the purpose of your analysis you should be able to replace the three capacitors with one capacitor that is the sum of the three values. In this case, 100+10+1 = 111uF.
  3. Firestorm
    Jan 24, 2005
    353
    yep hgmjr is right. It should only be 1 graph line (do the graph of 111uF cap. good luck :)
    -fire
