It will??You shold make a graph of the capacitative reactance as a function of frequency for these two capacitors. The difference will be apparent in great graphic detail...so to speak.
Yes, that is correct.So ceramic filter high frequency better while electrolytics filter low frequency better?
I thought the graphs would show precisely that. Is it your position that they show something else?It will??
The reason you use both types is that electrolytic capacitors are rubbish at passing high frequencies. A graph of theoretical reactance vs frequency will not show this.
Neither, at that value. You should use X7R ceramic 0.01uF.should i use a .01uF tantulum vs a .01uF electrolytic in an effort to scrub out high freq noise
by Aaron Carman
by Jake Hertz
by Duane Benson
by Jake Hertz
