I'm designing a boost converter circuit using a Linear 1302-5, and it works well with aluminum electrolytics for the output capacitors, but I was hoping to clean up the output a bit by using os-con capacitors instead. I tried Panasonic os-con with the same capacitance/voltage rating as the electrolytics I'm currently using, but the converter doesn't work at all with them. Is there an obvious reason that I'm missing?? Linear recommends Sanyo os-cons, and I would have thought the Panasonics would be very similar.
Thanks!
Thanks!
