Capacitors and Inductors
Discussion in 'Homework Help' started by Hello, Mar 21, 2009.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    Can you please have a look at Q3 part (i) in the attached file, as i am not sure if my answer is correct: V=IZ=I(Xc+XL)
    Any help is appreciated.
  2. recca02
    Apr 2, 2007
    1,211
    Did you forget to attach the file?
  3. Hello
    Dec 18, 2008
    82
    Yes, sorry.
  4. Hello
    Dec 18, 2008
    82
    This is the file.
  5. recca02
    Apr 2, 2007
    1,211
    The question (Q 3 i ) reads
    Write expressions relating current and voltage for a capacitor and an inductor.
    So going by that it should be
    I*Xc=V and I*Xl =V.
    you can also replace Xl = 2pi* frequency*L
    and Xc= 1/(2pi*Frequency*c)
    If you really want to use the given ckt dia. then you can always find the current using I = V/Z
    hope this helps.
  6. Hello
    Dec 18, 2008
    82
    Can you not write the expression as: V=IZ=I(Xc+XL) ?!
  7. recca02
    Apr 2, 2007
    1,211
    That would be an expression relating current through and voltage across capacitor and inductor in series combination not expressions relating current and voltage for a capacitor and an inductor.
