Why is the voltage measured at the capacitor in a air conditioning unit greater than the original supply voltage?
Because they don't manufacture capacitors with all possible voltage ratings one can use. There are some standard values and designers choose the most suitable for the design. If you use a lower value than the operating voltage it will blow thus they use the next higher value (at least).Why is the voltage measured at the capacitor in a air conditioning unit greater than the original supply voltage?
