Capacitor voltage rating with rectifier
Discussion in 'General Electronics Chat' started by mendiola_loyola, Nov 12, 2010.
  1. mendiola_loyola
    Sep 18, 2010
    16
    Dear All:
    I'm rectifying a 12V rms AC voltage using a diode bridge.
    I want to know how to calculate the capacitor voltage rating.
    Do I have to multiply 12 * 1.5 or 12*2 ?
    Thanks.
    Alfredo Mendiola Loyola
    Lima, Perú
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The multiplier to go from RMS to peak is 1.404. The voltage on the caps will be a bit less, due to the conduction drops across the diodes. For a good safety margin, use a capacitor voltage rating of about double the calculated voltage.
    So, 12 VRMS * 1.404 = 16.85 VDC. Use a capacitor rated for 35 volts.
  3. mendiola_loyola
    Sep 18, 2010
    16
    Thank you for your Help
    Lima, Perú
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Hey Beenthere,
    When did they change the value of the square root of two? :eek: I missed it. How do I update the programming on my TI calculator?:confused:
    Just kidding of course. My fat fingers frequently get me, too. At least yours are consistent.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wow, I've been dropping the 1 out of the value for years. For the record, it's 1.4142136 on my TI.
    Let's see, that's 16.97 volts.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Olde age tends to let us lock in pre-conceived notions. From your avitar, I can only guess tht I have a couple of years head start on you.
