The attached schematic is from the ST datasheet for the TDA2005R. What is the minimum safe voltage rating for the two 2200μF output caps assuming a Vs of 15 or less?
Thanks.
Thanks.
Thanks. I suspected that, but wanted a more knowledgeable person's opinion.For Vs=15V...
A 16V electrolytic is more than enough, but you can use higher voltage ratings if you have some handy, and room for the larger size. The highest voltage the cap will ever see is 15V, and then, only if the amp output has failed and is shorted to the VS rail.
Regards,
Ifixit
by Duane Benson
by Jake Hertz
by Jeff Child
by Jake Hertz
