Capacitor value question
Discussion in 'General Electronics Chat' started by Will777, Nov 9, 2010.
  1. Will777
    Sep 12, 2010
    48
    I am building a circuit which requires a 2pf ceramic capacitor as well as a 7pf ceramic capacitor.
    I cannot find these values, the closest I can get is 1.8pf and 6.8pf.
    Will this small difference in value make a difference to the circuit? The circuit in question is a model rocket tracking transmitter.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The wrong capacitor values might change the frequency of the transmitter if it doesn't use a quartz crystal. Then maybe the coil can be made with its turns a little closer together to get the correct frequency.
  3. Will777
    Sep 12, 2010
    48
    Thank you for the info.
    This circuit does not use a quartz crystal.
    So if I understand it correctly it will still oscillate, but the frequency might just be off? That is great news, I have a RF sniffer/freq counter that I can use to check the output freq.
