Capacitor Using Glass As Dielectric
Discussion in 'General Electronics Chat' started by DIVEKAR M S, Sep 11, 2007.
  1. DIVEKAR M S
    Sep 11, 2007
    :confused:
    I TRIED TO MAKE A CAPACITOR BY WRAPPING A 70 MM DIA BOROSILACATE GLASS TUBE, 2 MM THICK. I WRAPPED 50 mm WIDE AL FOIL ON THE OUTER SURFACE AS WELL AS 50 mm WIDE AL FOIL ON THE INNER SURFACE OF THE GLASS TUBE. I EXPECTED A CAPACITANCE VALUE IN THE RANGE OF ABOUT 20 nano F and while I got about 250 pico F only. I tried many tricks to check whether the aluminum foil was oxidised , thus resulting in poor cotact. I tried making capacitor using copper foil etc. But everytime I found capacitance vaue was just about 1 to 2 % of the value computed using standard formula for C given in text books. I think Borosilicate has relative dielectric ocnstant of about 4.5 to 5. Where did I go wrorng? Is simple wrapping of a foil sufficient or should the glass be coated to avoid thin layer of air?
    How can I make a capacitor which has avlue close to what is given by the standard formula?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use a larger vessel & see if the capacitance increases proportionally. Look up references to Leyden jars.
