capacitor(urgent!)
Discussion in 'The Projects Forum' started by braddy, Apr 6, 2007.
  1. braddy
    Dec 29, 2004
    83
    I am working with capacitor now and I have this question. I am applying a square wave (from 0 to 5V) on a RC circuit.
    At the output ( at the resistor) I get a positive and negative values? why is that ?
    I am suspecting the fact that the capacitor create a phase difference of -90 degree(between voltage and current)..but I cannot figure out the correct answer.
    please can someone help me?
  2. John Luciani
    Apr 3, 2007
    477
    when your square goes to 5V the capacitor charges to 5V (5V on the +terminal
    and 0V on the -terminal). Your square wave then goes to 0V so you now have 0V
    on the +terminal. Since the voltage across the capacitor cannot change instantly
    and the +terminal is 5V greater than the -teminal the -terminal has to be at -5V.
    (* jcl *)
    www.luciani.org
  3. braddy
    Dec 29, 2004
    83
    Thank you John!
