Capacitor Type
Discussion in 'Electronics Resources' started by robsworld, Nov 15, 2015.
  1. robsworld
    Nov 5, 2015
    22
    Hi, I'm trying to make a PCB with a digital-analog converter for the Arduino. I found a circuit that I want to use however there's a capacitor in it that I don't know. I look up caps on Digi-Key website and there are a lot of different types. Anyone have any idea what this one is? Its c4 a 10uf cap, looks to have polarity.
  2. ISB123
    May 21, 2014
    1,240
    531
    Electrolytic cap
  3. robsworld
    Nov 5, 2015
    22
    that didn't take long, lol, thanks! Just like the old can style?
  4. ISB123
    May 21, 2014
    1,240
    531
    Yes
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I don't see a C24?
    If C4 it can also be a Tantalum for small footprint
    Max.
  6. robsworld
    Nov 5, 2015
    22
    Sorry c4, I did see those expensive tantalum's, the cap is 1206 package.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    You have to be careful with tantalum - they're very intolerant of any reverse voltage!
  8. #12
    Nov 30, 2010
    16,665
    7,310
  9. robsworld
    Nov 5, 2015
    22
    What's the difference between tantalum and electrolytic?
    When I look on digikey for something I don't have electrolytic as a category. Which one is good? I believe I need at least 16v cap because the circuit is 12v DC and 1206 package would be nice.
    https://www.digikey.ca/product-search/en?keywords=10uf
    That mouser link is ceramic, those aren't polarity concerned. Those are what I'm using as bypass caps.
  10. #12
    Nov 30, 2010
    16,665
    7,310
  11. robsworld
    Nov 5, 2015
    22
    thanks but I still don't understand the difference? If this circuit was designed with a polarity sensitive cap shouldn't it still have that type? There must be some differences in all these. Right now my understanding is it doesn't matter what 10uf cap I put there but I know that's not correct.
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    As are just about any polarized capacitor or electrolytic!;)
    Max.
  13. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Not absolutely necessary to go electrolytic, just that once you get into that value, the physical size can become an issue.
    Tantalum usually offer a smaller physical size than common electrolytics.
    Max.
  14. robsworld
    Nov 5, 2015
    22
    Ah, so there is no SMD electrolytic cap? Tantalum would be the one to replace it if you want SMD?
  15. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
  16. robsworld
    Nov 5, 2015
    22
  17. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    That should work, per post#5.
    Max.
  18. robsworld
    Nov 5, 2015
    22
    Thanks Max and everyone else, just wanted to be sure. Simple things aren't always simple when you don't fully understand.
  19. ian field
    Oct 27, 2012
    4,447
    791
    Multilayer ceramic chip capacitors have surprisingly large capacitance for such small sizes, mostly they're SMD but a few suppliers offer resin dipped leaded types.
    They have among the lowest ESR figures of any types, most of the high capacitance ceramic dielectrics are very lossy at RF and the audiophools probably object to their use in audio gear.
