Capacitor type?
Discussion in 'General Electronics Chat' started by Gdrumm, Dec 20, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    Craftsman 19.2 v Impact wrench, won't turn on.
    Model No. is 315.116020
    When I opened it up, I found a burnt wire on one capacitor mounted in the trigger.
    I fixed that, but still nothing.
    Later, I found a piece half of another capacitor laying in the hollow of the grip.
    It was a hard plastic cap with the numbers 8A4 MIC
    It doesn't look like any that I have.
    The wire ends are very thick, like a high voltage cap from a Microwave Oven.
    Can I bypass these two capacitors?
    I've never seen a trigger with caps before.
    If not, where can I buy one? (I don't see it on Ebay)
    Thanks,
    Gary
  2. JWHassler
    Member
    Sep 25, 2013
    204
    34
  3. Lestraveled
    May 19, 2014
    1,957
    1,218
    The picture looks like a diode and the markings support that it is a 400 volt 8 amp diode. I think JW nailed it.
  4. Gdrumm
    Aug 29, 2008
    684
    36
    Of course it's a Diode.
    I can clearly see that, now that that I see the picture I TOOK....................
    DUH on me.
    What can I say, it was a long day.
    Thanks for helping me through that.
    Gary
  5. Gdrumm
    Aug 29, 2008
    684
    36
    Could I substitute a 1000v, 10Amp?
    Since this one basically broke in half, maybe a higher rated one would last longer?
    Or does a Diode need to be kept at design specs?
    Thanks again,
  6. Lestraveled
    May 19, 2014
    1,957
    1,218
    Yes, a 1000v, 10 amp diode should work fine.
  7. Gdrumm
    Aug 29, 2008
    684
    36
    Great, Thanks
