Capacitor temperature test
Discussion in 'The Projects Forum' started by JehanKhan, Jul 21, 2015.
  1. JehanKhan
    Oct 24, 2011
    9
    Hello All and Good morning
    I am trying to test the Electrolytic Capacitor temperature rise and then measure it with a IR camera. what i did is used to MOSFET with 50% duty cycle and connected to the inductor with the capacitor as a filtering capacitor and a load resistance to draw some amps of current. The peak triangular current i got about 3amps. For small capacitors it works better but i did not succeeded with a 330uf capacitor.
    And i am thinking to do it with only MOSFET so that i can put as much stress as i can to generate a pulsating current in order to make the capacitor warm. I need advise about this idea. If i should do it? and if i can get some suggestions that would be great.
    Thanks in advance
  2. DickCappels
    Aug 21, 2008
    2,753
    665
    If you only use a MOSFET, what will keep the capacitor from charging up to a peak voltage and staying at that voltage? If the voltage across the capacitor doesn't change, there won't be any current to heat it up.
  3. JehanKhan
    Oct 24, 2011
    9
    Yes you are right i put a resistor in parallel to it to discharge the capacitor. and it worked :)
    thanks for the response anyway. cheers
