Capacitor Switching Cycle
Discussion in 'Homework Help' started by notoriusjt2, Oct 29, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    this is a random question that has no examples or explanations in my text book
    how do I find any value if no values are given to me? plus it says "determine Vo" but every answer is a value for Vs which throws me off even more.
    where do I begin with this one?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    The output will be a function on the input.
    Draw the two states as separate, complete circuits.
    Pay attention to the charge polarity on the capacitors at the point where switch 1 is closed and switch 2 is opened, what do the series voltages add up to?
  3. notoriusjt2
    Feb 4, 2010
    209
    the capacitor is represented by two vertical bars. does the thicker bar represent the positive terminal?
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Not necessarily. It is irrelevant to the exercise. Treat it as a non-polarized capacitor.
    Draw the 2 different circuits and examine them.
    Keep in mind that two capacitors connected in series share the voltage applied to them.
  5. notoriusjt2
    Feb 4, 2010
    209
    in the first part of the switching cycle the two capacitors are in series. so they would split the applied voltage. If Vs=10V then each cap would charge to 5V
    the second part of the switching cycle puts both cap's in parallel with the load(Vo). because the voltage polarity is now applied to the other side of the cap, Vs would get added to the cap voltage. sticking with Vs=10V, we would add the 10V to the already charged 5V to get 15V. am I correct in my assumptions?
  6. notoriusjt2
    Feb 4, 2010
    209
    and even if I am correct, I still dont understand how I can pull values out of thin air to get one of the answers in the multiple choice
  7. notoriusjt2
    Feb 4, 2010
    209
    ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.... the answers are actually in the form of (x)(Vs) not x = Vs.
    so if Vs=10 and after the entire switching cycle the cap was equal to 15V
    then
    (1.5)(Vs) is my answer
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yes, that is the correct answer.
  9. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Sorry, but 1.5 Vs is not the correct answer.
    Take a good look at the direction of the capacitors when charging (switches 1 closed)
    and when discharging (switches 2 closed).
    Bertus
  10. notoriusjt2
    Feb 4, 2010
    209
    are you in agreement that both caps will be charged to 5V each during phase 1 of the switching cycle? this is assuming that Vs=10V
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    In position 1: The capacitors will be charged in series, each at 0.5 \cdot V_s with the + potential being the left terminal in the drawing above.
    In position 2: The two capacitors will be switched to parallel, with their "negative" terminals attached to the positive terminal of Vs. This will put the 0.5 \cdot V_s of the capacitors in series with 1 \cdot V_s, for a total of 1.5 \cdot V_s
  12. notoriusjt2
    Feb 4, 2010
    209
    I concur... I was targeting that last post towards Bertus because he is in disagreement with what I think is the answer
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    After the capacitors are charged and disconnected from Ground, they ought to keep their load, shouldn't they. Bertus, why do you suggest they discharge at phase 2?
    Starting from the + terminal of the battery, we cross the left capacitor from its - terminal to the + terminal. That means that the voltage level will increase by the amount of the voltage applied on the capacitor. Thus V_s+0.5\cdot V_s=1.5\cdot V_s
  14. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Ok I see.
    Bertus
