I have a 12v, 13a fuel pump that doesn't always start with the ignition key. I have checked the circuit, cleaned all the connections and grounds, dielectric greased all these connections but from time to time the fuel pump fails to start. Electrical system otherwise checks out fine.
If I tap on the fuel pump it will start and run fine. I have replaced it a couple of times now, rewired it, and just wish to give it a higher voltage kick at start up. What size capacitor should I use, and how would it be wired in.
