Hello everyone.
Im currently constructing the 4th order sallen key low pass filter with 500Hz cut off frequency as shown in this attached figure. Im also constructing a 4th order sallen key high pass filter with 100 Hz cut off frequency. Im cascading the low pass filter and high pass filter to form a 8th order band pass filter with frequency range from 10Hz to 500Hz.
Im not sure what type of film capacitors (polyester or polypropylene) should I use for the 3 nanofarad capacitors in the low pass filters and 33 nanofarad capacitors in the high pass filter. Or should i use ceramic or monolithic capacitors instead to implement this band pass filter? I am using Texas Instruments OPA277 precision operational amplifiers.
In Malaysia where im at we have a branch of Farnell-Newark electronic parts supplier but no Mouser or digikey.
