capacitor resistor circuit exercise book question REVISION
Discussion in 'Homework Help' started by ign804, Dec 11, 2007.
  1. ign804
    Dec 11, 2007
    Attachment Is Circuit Diagram I Need To Find Out
    1 The Time In Milli Seconds For The Capacitor Voltage To Reach Your Value Of Charge Voltage
    2 The Value Of Capacitor Voltage After The Value Of Charge Time
    3 Assuming The Capicitor Is Fully Charged The Time In Milli Seconds For The Discharge Current To Reach Your Individual Value After The Switch Has Been Opened
    4 Assuming The Capacitor Is Fully Charged The Value Of Discharge Current At Your Individual Value Of Time After The Switch Has Been Opened
    Will Someone Be Able To Do This One And Show Me Working Out So I Can Do Second One On My Own
    • EX.doc
      File size:
      27 KB
      36
  2. mentaaal
    Oct 17, 2005
    451
    Problems like these are easily solved with the formula in the attachment.
    Just plug in the values supplied to find the unknown.
    the charge voltage i presume to be the voltage accross the capacitor and the charge time you put in for t etc. (i think anyway)
    [​IMG][​IMG][​IMG]
  3. ign804
    Dec 11, 2007
    Really Still Stuck Will You Be Able To Show Me Anyone So I Can Use This As An Example
  4. mentaaal
    Oct 17, 2005
    451
    Ok take a look at the attachment
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  6. ign804
    Dec 11, 2007
    any more help really cant get head round it:mad:
  7. Distort10n
    Dec 25, 2006
    429
    Where did you get those answers from? Charging time cannot be ~9ms through 220 ohms and 33mF.
  8. ign804
    Dec 11, 2007
    any help please
  9. Distort10n
    Dec 25, 2006
    429
    Boy did I read this question wrong. Did Mentaal's explanation help at all or do you need a completed example?
