Capacitor replacement
Discussion in 'General Electronics Chat' started by lubnaan90, Apr 1, 2010.
  1. lubnaan90
    Thread Starter Active Member
    Jan 13, 2010
    196
    Hello to All,
    Is it appropriate to use 2200uf capacitors as a replacement of 2000uf capacitors ?
    Note : The capacitor is to be replaced in an old soviet made Power supply unit.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    As long as the voltage of the capacitor is equal or higer rated.
    Capacitors can have up to 20 % tolerance.
    Bertus
  3. lubnaan90
    Jan 13, 2010
    196
    Thanks a lot for your immediate reply.
    Its been long since i red from you.
  4. retched
    Dec 5, 2009
    5,201
    313
    Check out bertus' cell phone camera ring flash. good idea.
    As for the caps, I would agree. the 200uf can be such a small variance that stray capacitance is usually indicative of, so as long as your PCB is well made, you shouldn't notice a difference with a small difference.
