Capacitor questions
Discussion in 'General Electronics Chat' started by Flug540, Jan 25, 2013.
  1. Flug540
    Mar 24, 2012
    60
    Hi All,
    I need some help in an attempt to understand a schematic (attached). In the top right corner is a 12V-to-5V MC78M05 voltage regulator. What I don't understand is why they have so many parallel capacitors there? C7 and C8 on the output side and C9 and C10 on the input? Based on the IC reference the input side only needs 0.3uF and the output 0.1uF. I assume they added the electrolytics to add stability in case 12V source isn't stable enough? If that's the case, why is C9 still needed, can't it be replaced by C10?
    Also, is the component placement critical, for example, when designing the board, can we move C8 next to C3 for example?
    Sorry for the noob questions and thanks in advance!
  2. kubeek
    Sep 20, 2005
    4,689
    806
    C1,2,3,4 need to be close to the max chip. Electrolytic caps have high ESR and perform poorly at high frequencies, so you add a ceramic cap in parallel which doesn´t have much capacitance, but will work well above what the electrolytic can handle. Check this video http://youtu.be/TDDoi70cxw0?t=4m25s
    SPQR likes this.
  3. Flug540
    Mar 24, 2012
    60
    Awesome, thanks a lot!
  4. ScottWang
    Aug 23, 2012
    4,930
    777
  5. Flug540
    Mar 24, 2012
    60
    Great reading, thanks!
