the capacitors that look like ceramic ones but have slipery plastic cover are these mylar capacitors. some are also longer oval shaped. will a electrolitic capacitor explode if polarity is wrong or voltage exceded.
They could be mylar if they're old but chances are they're both common Polyester Film Capacitors which have replaced most smallish - mid value caps. They're relaible, inexpensive and spec out pretty good for their price.the capacitors that look like ceramic ones but have slipery plastic cover are these mylar capacitors. some are also longer oval shaped. will a electrolitic capacitor explode if polarity is wrong or voltage exceded.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Robert Keim
