I would like to get some clarifications on a capacitor ...
I have uploaded a picture to explain my questions ...
1) when the capacitor is charging, I assume that electrons build on lower plate of capacitor.
What happens to the upper plate. Physically, is there an opposite of electrons?
2) what would happen if upper plate of capacitor is open or is not connected to positive terminal of supply?
Would the capacitor still charge?
Even this case, the lower plate of capacitor's voltage is lower than negative terminal of supply.
So, capacitor should charge.
3) In the figure, what would happen if instead of load we have another capacitor of same capacity?
Would the second capacitor charge half way through and then settle down?
Thanks a lot ...
Thanks a lot ...
