I am in the process of building an ac to dc variable voltage power supply. I am running the 120V 60Hz ac through a stepdown transformer which will lower the voltage to 24V. I am then going through my rectifier circuit, 4 diodes arranged for full wave rectification. here is my question:
I know that ac voltage displayed on a voltmeter is RMS voltage and components need to be sized for FULL voltage which would be peak to peak voltage...this would be 1.414*24*2. This would give me just under 70V. Now this is on the AC part of the circuit. After the rectifier circuit I will be adding a couple smoothing capacitors. The capacitors will be on the DC side of the rectifiers so can I use capacitors rated at anything over 24V because DC voltage has no peak to peak and is a constant voltage?
