Capacitor question
Discussion in 'General Electronics Chat' started by Guinness1759, Jan 26, 2011.
  1. Guinness1759
    Dec 10, 2010
    64
    I'm looking for the a word or term that refers to the following. When you have a capacitor that has charge stored on it and some of that charge is drawn away quickly, for example in the case of a transmitter, the voltage drops way down but comes back up after the transmitter is turned off. The capacitor is by itself without external voltage source supplying it power, so it's like it charges itself back up, not quite to the original level obviously. This is happening with large capacitors, such as 5F or 10F.
    I'm noticing this happening and I need to write about it, but can't think of the word that describes this behavior, or if there is one. Thoughts?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Rebound?
    It happens in many systems and can result from taking your measurements before equilibrium/steady state is reached.
    John
    Guinness1759 likes this.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Rebound has to do with internal parasitics of the capacitor. The bulk of the capacitors charge can be "dumped" quickly, leaving one to believe it is discharged. With large value caps and/or high voltage, there is more charge "deeper" in the structure of the capacitor that cannot be drained as easily.
    Once the majority of the current is dumped, if the terminals are left with no load (disconnected), these charges will migrate to the areas where they can be quickly dumped, giving the appearance of the capacitor "recharging itself". This charge can build up a few times, though weaker each time.
    The only analog I can think of is when you run an Alkaline battery dead, if you turn the item off for a ten minutes, you can usually get more use from the device from the "dead" batteries due to a similar chemistry effect.
    Caps taken out of high voltage/high capacity circiuts should have a 100k or so resistor shorted across the terminals for continual equalization of the plates.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    How about if you have a hot date and the next morning, she decides she hates you. Does that count as another example?
    John
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We need a "smite" button. ;)
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    You are thinking of NiCd batteries.
  7. magnet18
    Dec 22, 2010
    1,232
    125
    Unless you try to get back together after this happens, but you slip up in the get-together phase just once, and she blows up in your face and is gone forever. Then its a LiPO battery.
  8. Adjuster
    Dec 26, 2010
    2,147
    300
    This type of behaviour can be a serious safety hazard with some types of high voltage capacitors. Even if they have been discharged after being used or tested, it is possible for a dangerous voltage to build up across them some time later.
    Because of this, it is usual to store such components with their terminals short-circuited.
