Most power supplies only regulate the "main" output. The other lower power supplies then track that output. Try loading the 5 volt supply while your motor is plugged into the 12 volts. (This assumes that the 5 volts is the main output. There may be a 3.3 volt, or such, instead.)Yes the problem is in the PSU.I'm running a DC motor that draws around 5A max.
I can use the motor on 5V line without problems but as soon I plug it into the 12V line psu shuts down.Generally if I try to draw more than 10W from 12V it just shuts down.
A question: What is the 12 volts rated for? 10 watts may be all you can get.
