A capacitor in an AC circuit will charge and discharge with respect to the frequency of the signal voltage. Impedance in the circuit is proportional to this frequency and its capacitance. In a power supply the current is regulated through the discharge cycle. What happens to the energy when there is no place to discharge to? Just a capacitive load.....
"This means that a capacitor does not dissipate power as it reacts against changes in voltage; it merely absorbs and releases power, alternately. "
Does this statement mean that all ESR and leakage inefficiencies aside there will be no current in the primary of the transformer beyond the initial charging of the capacitor??????? If this is the case what are the considerations for capacitive loading of a transformer just the initial spike and the inefficiency resistances of the capacitor and transformer??? Is the current through the secondary still a limiting factor???
