I have a pair of identical monitors: one has gone bad and the other has a transient when you first turn it on (flickers for about 20 seconds), which I interpreted as it was about to go bad too. So I took apart the monitors to look for signs of capacitor plague.
I found some white substances near the capacitors (please see attached pics) which I thought might be leaking dielectric, but all the pictures I've found of capacitor plague show caps with distressed vent-domes -- which mine don't have -- and they don't show the white substance.
The only other thing I can think of is that its some kind of glue, but I have no idea why you'd need to glue down a component in a monitor...
If anyone can confirm that these capacitors are indeed bad, I'd be appreciative.
Thanks.
[First pic is from signal processing board; second is from the power supply board]
Thanks.
