I'm trying to make a quick charger for my 36v 150ah battery pack using ether inductors or capacitors and a high current rectifier. I'll be powering it with a ground isolated 2kw generator. It'll only run for a couple minutes at a time while I monitor voltage, current and temp. Which would be better, capacitors or inductors? I've already built one successfully with induction motor run caps but it took dozens of them for an 8 amp power supply, but I'm looking for closer to 30 amps. I've also been considering a mercury vapor 400 watt ballast with the secondary coil re-wound for the lower voltage. The batteries may have up to 25 amps being drained from them while charging.
