Capacitor Monitoring
Discussion in 'General Electronics Chat' started by Circuits101, Mar 16, 2011.
  1. Circuits101
    Feb 24, 2010
    11
    How can I monitor the current charge state of a capacitor bank during charging. I would like to display the amount the capacitor is charged with an LED bar graph and then when it is fully charged stop charging.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The simple answer is voltage. A cap will charge to the power supply voltage and stop.
    It does so using a RC charge curve, which is approx 63% per TC (time constant, TC = R X C).
  3. Circuits101
    Feb 24, 2010
    11
    Ok so I can just measure voltage across the capacitor similar to a battery and then do a voltage divider to power the LEDs
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Or get the answer on chiphacker.
  5. Talguy
    Member
    Aug 17, 2009
    14
    yea a capacitor acts similar to a battery.
  6. studiot
    Nov 9, 2007
    5,005
    515
    No a capacitor does not act 'similar to battery' during charge.
    A battery will not exceed its peak charge voltage
    A capacitor will continue charging towards the charging voltage
    So charging a nominal 12v battery from 20 volts will get the battery up to about 14.7 volts.
    Continued attempts to charge beyond this may well damage the battery.
    Charging a capacitor from 20 volts will quite quickly bring the capacitor pretty close to 20 volts.
    Obviously the rates depend upon circuit resistances.
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    Use an LED bar graph driver like the LM3914. It will convert a 0-1 volt analog input into 10 distinct LED outputs. You can cascade them to have many more LED's.
    http://www.national.com/ds/LM/LM3914.pdf
    The easiest way is a good old NE-2 neon lamp and the right resistor.
    Maybe you can get some tips from photoflash capacitor monitoring circuits.
  8. jaclement
    Apr 15, 2009
    34
    If you are chargiing the capacitor bank with a resistor in the positive suppy, you can put an LED and resistor that are in series across that resistor. With the right size current limiting resistor, the LED will glow brightly at the start, and get dimmer as the bank charges. The LED will go out,however before the bank is fully charged
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Or you could use a voltmeter.
