Capacitor Issues
Discussion in 'General Electronics Chat' started by big_stag, Oct 24, 2013.
  1. big_stag
    Oct 24, 2013
    We recently (1 year) installed a new production parts cleaner. Installed with this cleaner for the heat source for the cleaning solution is electric heaters. There are two tanks with 4 3PH 480VAC 18KW heaters in each tank. From time to time it blows a main fuse 200A fo ther cleaner the same leg each time. Which also blows a 300A fuse that feeds to our plant capacitor bank.
    Is there a correlation between the two?
    I am not a Electric Engineer by no means...
    rmonroe
  2. PackratKing
    Jul 13, 2008
    850
    216
    How old is the facility all this is in...?
    That kind of wattage going to heat liquids, if it has a short duty cycle to maintain a given temp of the liquid, needs the physical connections of power cabling checked for loose or corroded / tarnished connections... and the contact condition of any relays that cycle within the circuitry...
    3 Phase... are the lines in balanced w/ respect to the high voltage ? It sounds as though the one leg is working harder than the others ?
    I am certainly no 'expert' either, there are others here that are likely to be better able to diagnose your issue...
  3. gerty
    Aug 30, 2007
    1,154
    304
    Have you measured the current at each heater element? 200 amps seems awfully high for what you describe, is there anything else on that circuit. And how does the 300amp circuit figure in?
  4. wayneh
    Sep 9, 2010
    12,379
    3,234
    Working with 144kW is not a chore for an inexperienced person, and no expert here should feel comfortable offering remote advice to a beginner on a system they cannot see.
    Be safe. Call a professional.
    PackratKing likes this.
  5. gerty
    Aug 30, 2007
    1,154
    304
    I missed the the 4x the first time I read this:eek::eek:
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Is it the cleaner or the cap bank?
    Is this a power factor correction capacitor?
    Max.
