Capacitor Identification
Discussion in 'General Electronics Chat' started by emmy, Aug 9, 2006.
  1. emmy
    Aug 9, 2006
    22
    Hello all,
    I am having trouble finding some data sheets on two Nichicon Capacitors.
    UPL1E101MPH this is a 25V/100uf but thats all the info I have
    UPL1V102MRH this is a 35V/1000uf again all the info I have.
    I am looking for data sheets or and equivilant for these units.
    Any help would be great.
    Emmy
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Unless you have some critical application in mind (low ESR, high temperature, etc), any capacitor with the same lead arrangement and capacity and voltage should do ok for a sunstitute.
    If they are a thight fit, check diameter, too.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Having done a little digging round the net, there doesn't appear to be available the datasheets for the said capacitors. Most places that claim to give you the options to download the datasheets require you have a log in. So other than someone having a copy of them stored locally I'm not sure how you can go about getting them.
    You could also possibly request the datasheets from over at http://www.alldatasheet.com/
    I am also moving this to the General Electronics Chat forum.
    Dave
