capacitor help
Discussion in 'The Projects Forum' started by markosillypig, Oct 21, 2009.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all
    i have made this circuit today only problem is it says use a 47uf 6.3 v but i do not have any 6.3v but i have 10v and 16v 47uf will ether of them substitute the 6.3v withoud damage to the rest of the circuit
    thanks
    marko
      File size:
      229.9 KB
      17
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yes. For polarized capacitors, you can use a higher voltage rating than specified. I wouldn't go so far as to use a 500V polarized cap in a 9V circuit.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The "rule of thumb" for capacitors is to use twice the rated voltage as you may see across the capacitor in the circuit. Since the output of the regulator is 5v, you should use a cap rated for 10v.
  4. markosillypig
    Jul 21, 2008
    184
    thank you both
    i thought you could use higher voltage but just wanted to be sure
    thanks
    marko
