I have a TV I'm trying to fix. I do know a bit about electronics, but not a lot The power supply is making a weird buzzing sort of sound and will eventually shut off until it cools down. Here is a picture of what I'm looking at
http://www.whtech.ca/owncloud/index.php/s/MUCxXmSqiTuQj78
I replaced the capacitor that is on top of the small black heat sink. But I think the sound is coming from the grey rectangular capacitor that is below the small heat sink. It is a MKP 25 - 150K 450V? Is how I read it. The top capacitor reads nothing on the ohm meter, the bottom does have a reading. Both are the same from what I can tell.
I don't know much about these. Will they make this weird buzzing sound? Can they be replaced with standard capacitors? Can anyone direct me as to where to find them?
Thank You!
Walter
Thank You!
Walter
