capacitor for crystal
Discussion in 'Embedded Systems and Microcontrollers' started by pasha4686, Jul 26, 2008.
  1. pasha4686
    Jun 22, 2008
    hi electronic funs i have problem about a pic project i want to measure frequency between 10-20Hz using with PIC and i use to CCP unit from PIC...CCP(capture compare pwm) uses TIMER1 and TIMER is a 16 bit counter if i use 4mhz crystal;4mhz/4=1mhz and then 1/1mhz=1us(microsecond) timer1 is maximum 65536; 1*65536us=65536us and then 1/65536=15,25 hz
    i cant measure between 10-20hz i think if i choose 2MHZ crystal i will solce this problem but if i choose 2 MHz crystal which capacitor i will use pls help me....thanks good works...
  2. pasha4686
    Jun 22, 2008
    if i use between 15-33pf capacitor it will be ok?can anyone help me pls?(4 mhz-22pf)
  3. roddefig
    Apr 29, 2008
    149
    The crystal datasheet will usually specify the recommended capacitors.
  4. nanovate
    Distinguished Member
    May 7, 2007
    665
    The PIC has a prescaler that reduces the timer frequency ... read the datasheet and it'll tell you how to use it....
  5. pasha4686
    Jun 22, 2008
    thanks for your reply
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  7. pasha4686
    Jun 22, 2008
    Bertus thank you very much for your help that page is very useful about crystal oscillator....Good bye....
