Capacitor for a PWM controlled DC motor
Discussion in 'General Electronics Chat' started by atferrari, Jul 21, 2010.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,662
    782
    I am currently completing the assembly of a small coil winding machine driven by a 12V/45 mA PWM-controlled motor.
    At two different robotic oriented sites I have found the recommendation of adding a capacitor to its terminals allegedly to protect the motor.
    If true, what is the actual reason to use it? How to calculate / check the value of C?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    I think the 4QD site explains it. You can find a lot of interesting information there. Are you using two mosfets or just one? Here is the link to the first section in which the "main" capacitor for a half bridge is described: http://www.4qdtec.com/pwm-01.html
    John
  3. atferrari
    Jan 6, 2004
    2,662
    782
    Four 2N1711 (bipolar) in a full H bridge driven by PWM signals from a 18F452.
    Thanks for the link, John.
