A circuit I'm using calls for a couple capacitors that I can't seem to find. Since most capacitors have a tolerance of +-20%, as long as the capacitor is within a couple pF it should be fine right?
Whoever chose those component values must be nuts. Just round the last digit to zero.
Let's do one at a time. First the transmitter:
Item
Value
Substitute
Comment
C1|203pF|200-100,000pF|non-critical filter cap
C2|47μF|10μF-100μF|non-critical supply filter cap
C3|47|47|non-critical
C4|68|68|non-critical
C5|203|200-100,000|non-critical filter
C6|68|68|non-critical
C7|203|200-1000|non-critical HF filter
C8|151|150|non-critical
C9|151|150|tuned tank circuit will depend on L3 in any case
C10|103|100|tuned tank circuit will depend on L3 in any case
Thanks Mr chips! That's pretty much what I thought. The only ones that are important to have really close capacitance to what's written are the ones from L3 to ground.
There is a strong possibility that someone transcribed the values incorrectly from another schematic:
Item
Marking
Value
Comment
C1|203|20nF|non-critical filter cap
C3|47|47pF|non-critical
C4|68|68pF|non-critical
C5|203|20nF|non-critical filter
C6|68|68pF|non-critical
C7|203|20nF|non-critical HF filter
C8|151|150pF|non-critical
C9|151|150pF|tuned tank circuit will depend on L3 in any case
C10|103|10nF|this one does not seem right
As far as I know 27.000MHz is not a legal frequency.
Operating at this frequency will interfere with CB Channel 4 operating at 27.005MHz.
There is a 10kHz separation between legal alloted channels in the 27MHz band which has been allocated for CB and RC.
Get yourself some of these. Do not get the ones without the encoder/decoder chips.
I am using 4 of the 315MHz transmitters and one of the receivers. I mounted the receiver inside a weatherproof fullsize 1/2 wavelength vertically-polarized Dipole antenna which is mounted on the outside front of my metal hangar building. I am able to open/close a swing gate, two garage doors, and the aircraft hangar door from a distance of about 100m from the inside of of a car.
It is all about how good the receive antenna is, and where it is mounted....
Both the transmitter and receiver should have a crystal to set them at the same frequency right?
And is this a better circuit for what I'm trying to do?
