Capacitor Correcting Power Factor
Discussion in 'Homework Help' started by jegues, Sep 24, 2011.
  1. jegues
    Sep 13, 2010
    I feel fairly comfortable with this question, however I have some concerns about the signs for certain values throughout the problem.
    First concern, the negative sign on the angle θ from the PF, does it matter that I put it to -36.87°?
    The voltage across the load sits at 0°, and since the PF is lagging, the current should be behind the voltage, hence my reason for the negative sign.
    Note that I did this for the angle for the new PF in part 2), which brings my next question.
    Since I made θ and α negative angles, my reactive portions of the power come out as negative, which is okay but how do I get rid of the j in the impeadance for the capacitor in the expression,
    Q_{cap} = V^{2}(j\omega C)
    Are we only considering the magnitude?
    If that's the case then the j disapeers, but how do I get rid of the negative on the LHS?
    Is this the right way of thinking about it?
    EDIT: I realized I've made mistakes in the first portion of the question.
      File size:
      16.4 KB
      File size:
      50.4 KB
  2. mik3
    Feb 4, 2008
    Note that the angle of I is negative but not the angle used in cos() and sin() since S=VI*.
    To get rid of j you can set it as a 90 degrees angle.
