Capacitor Conundrum
Discussion in 'General Electronics Chat' started by richbrune, Feb 3, 2006.
  1. richbrune
    Thread Starter Senior Member
    Oct 28, 2005
    106
    I recently purchased two large capactors. After desiging a circuit and a case that they would go in. I realized that the markings on the capacitor were wrong. I'd like to know if there's some kind of test that will tell for sure what the polartiy is, so I don't need to get a new hair-doo.
    Attached is a photo of the capacitor. I think it's an electrolytic.
    Thanks again,
    Rich
  2. pebe
    Oct 11, 2004
    628
    Can't see the photo. What is the capacity and voltage rating?
  3. richbrune
    Oct 28, 2005
    106
    I'll try again, but its a 70 volt, 3,600 MFD wit about a 2" diameter case and about 6" long.
  4. pebe
    Oct 11, 2004
    628
    You could try putting approx 10 volts on it via a 100 Ω resistor and measure the leakage current. Then discharge it and reverse the polarityand test again. You will probably find a difference in leakage current - correct polarity gives lowest current.
