Capacitor charge time question
Discussion in 'The Projects Forum' started by Fobio Design, May 31, 2016.
  1. Fobio Design
    May 11, 2016
    17
    Hello-
    Thanks for taking the time to read my thread. I have a simple question (I think). My question is in regards to how long it will take for a 10uF capacitor to charge when being powered by a 9V 600mAH?
    Thanks!
  2. #12
    Nov 30, 2010
    16,665
    7,310
    With no resistance involved, the answer is zero.
    Assuming the 9v source has some internal resistance, the answer is:
    Vcap = 9v e^(-time /RC)
    Fobio Design likes this.
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    The charge time of a capacitor depends upon the resistance in series with the capacitor (the RC time-constant).
    So if you have no added resistor then it depends mainly on the resistance of the battery, the wire, and switch connecting the battery to the capacitor, as well as the capacitor ESR.
    The 600 mAH is the battery capacity and has nothing directly to do with the capacitor charge time.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Using tex:
     \small V_f = V_ie^{\frac{-t}{RC}}
    The capacitor will be completely charged in 5 RC time constants.
    EDIT: As has been pointed out, this is the formula for a capacitor discharging.
  5. tcmtech
    Nov 4, 2013
    2,107
    1,747
    For the lazy people this is easier and more satisfying.
    Calculators for everythign you cna think of and more. http://mustcalculate.com/ :cool:
  6. dl324
    Mar 30, 2015
    3,376
    651
    For the R and C in question, less than a microsecond.
  7. shortbus
    Sep 30, 2009
    4,088
    1,670
    Not to hijack the thread, but a similar question on the subject. How far away from the capacitor, in device terms not distance, does a resistor effect the RC time? Say a linear power supply with a current limiting resistor connected to a mosfet acting as a switch connected to the capacitor. Would the current resistor or the RDSon of the mosfet be considered the "R" in the RC formula, or both?
  8. dl324
    Mar 30, 2015
    3,376
    651
    It's the sum of all resistances in series with the cap.
    shortbus likes this.
  9. shortbus
    Sep 30, 2009
    4,088
    1,670
    Thank you for clearing that up for me.
  10. crutschow
    Mar 14, 2008
    13,475
    3,362
    And if it's a low resistance you may need to include the capacitor ESR.
  11. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    Since the question says 600 mAh, it sounds like the source might be a rechargeable 9V battery? It will have an internal resistance, as others have mentioned. If it's a good NiMH, that could be as low as 0.1 ohm. As DL324 says, most engineers consider the capacitor to be fully charged after 5 time constants.
    Example:
    R = 0.1 ohm
    C = 1 uF = 1 x 10^-6 F
    Time constant = RC = 0.11 x 1 x 10^-6 = 0.1 uS
    5 time constants = 5 uS.
    So about 0.5 uS to fully charge.
    If you use another kind of 9V battery, the time will likely be longer. This may help http://www.learningaboutelectronics.com/Articles/Battery-internal-resistance
  12. crutschow
    Mar 14, 2008
    13,475
    3,362
    That equation is for discharging a capacitor through a resistor.
    For charging a capacitor the equation is:
    where Vc is the capacitor voltage and Vs is the source voltage.
    As to when it the capacitor is fully charged, it depends on how you define "completely". ;)
    It will charge to 99.3% of the final value in 5 time constants.
    In 10 time constants it charges to 99.95% of the final value.
    Worst-case I suppose you could say it's completely charged when the capacitor voltage is within ±1 electron of equaling the source voltage.
    I'll leave that time calculation as an exercise for the reader. :rolleyes:
    Hint: I think it something over 40 time constants.
  13. dl324
    Mar 30, 2015
    3,376
    651
    Thanks for point that out. I wasn't thinking and just used information from an earlier post.:eek:
  14. wayneh
    Sep 9, 2010
    12,374
    3,226
    For what it's worth, 3 time constants often is enough to get within error ranges of being "fully" charged or discharged. The closer you look, the longer it takes.
