capacitor burned up
Discussion in 'The Projects Forum' started by 1-3-2-4, Oct 12, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I have a orange drop 600V rated capacitor and .1 uF So in the schamatic it shows as being connected to three sockets and the 115 V AC line, and the wire from the relay to the capacitor.. well I powered up the circuit and got no sound and in 10 seconds later I had some smoke released, given the damage it looks like it was the capacitor.. What I don't get is what is the cause of it burning up?
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Could be 'natural' failure, probably hard to tell at this point what caused it.
    Usually the orange drop are pretty good, did someone replace an original wax paper type, I wonder which are usually inferior?
    That an oldie with Selenium rectifiers!
    Max.
  3. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Are you sure that W.W. resistor was not pressed against it?
    Max.
  4. tubeguy
    Nov 3, 2012
    1,157
    197
    +1
    Yes, the brownish wire wound resistor looks nasty.
    EDIT: Do you have an organ to go with this Leslie speaker?
  5. #12
    Nov 30, 2010
    16,671
    7,314
    That's how Orange Drops pop! They blow a chunk out through the casing. I even have one that popped, brand new! Why? Because it was defective. That's all. Some parts are born bad, some go bad, some go to the landfill still perfectly good.
    Of course, the next question along this line is, "Why did it fail today?"
  6. 1-3-2-4
    Dec 26, 2008
    194
    I'm almost sure nothing was touching
    Yes it's connected to a Hammond C3
    When I first turned it on the motors came on like normal but I had no sound, then I saw a little glow from that cap then came the smoke. So if this is how they pop how did the older stuff let go?
