capacitor burn out, AC power circuit...
Discussion in 'General Electronics Chat' started by merry80, Nov 19, 2010.
  1. merry80
    Sep 9, 2010
    14
    C1,C2,C3,C8 burned out after one year working (3*230Vac power supply line). C1,C2,C3,C8 are all ceramic capacitor, 103Z/1kV.
    The resistance of these failure caps is all about 30R.
    Dose the quality of these capacitor be the root cause for this failure? or the selection of these capacitors in designing stage was not so suitable. Maybe we should pick a capacitor which has much high rated voltage, for example 2kV ?
    And i can't work out why C8 was damaged. I thinks there is no much electric stress on C8.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you might've had some kind of hefty transient spike (like lightning) that took them all out at once.
    You might consider using MOVs or TVRs from the phase A,B,C inputs to Neutral.
    Interesting about C8 - what's the difference between GND and GNDH?
  3. Dwighthe
    Oct 27, 2010
    Are the MOVs in parallel with the capacitors still good? If the caps failed due to high voltage I would change the MOVs since they have undoubtably been stressed.
  4. merry80
    Sep 9, 2010
    14
    MOVs are still good. Did you mean that I have to choose a MOV which have a lower varistor voltage? so MOV can work in time to protect the capacitor.
    The spike damaged the capacitor, but not enough to make MOVs to start working.
  5. merry80
    Sep 9, 2010
    14
    i have used MOVs parallel with capacitor---VDR1,VDR2,VDR3 in schematic.
    MOVs are good, not damaged. So, i think transient spike is not root cause.
    I don't know exactly the difference of GND and GNDH. Maybe they are the Digital ground and Analog ground.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    The caps should be X caps, or Y if only going to ground (the schematic indicates X rated needed). They are typically packaged in a plastic box, rather than the usual epoxy dip.
  7. Dwighthe
    Oct 27, 2010
    A full wave three phase rectifier generates third, fifth and higher order current harmonics on the input side of the bridge. The capacitors are there to shunt the harmonics to the neutral. The capacitive reactance goes down as the frequencies increase which is usually not a problem since the voltages for the higher orders are low. But if the three phase input is un-balanced or a diode is open then the harmonic voltages would increase and cause the capacitors to overheat.
