Capacitor breakdown voltage
Discussion in 'General Electronics Chat' started by mahela007, Sep 3, 2011.
  1. mahela007
    Thread Starter Active Member
    Jul 25, 2008
    45
    In practical applications, will there be any difference in performance between two capacitors which have identical characteristics except for their breakdown voltage? More specifically, will there be a difference in performance in a series LC (inductor capacitor) circuit?
    Of course, it must be assumed that both capacitors operate at voltages lower than their respective breakdown voltages.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There may be a difference in the leakage rate, depending on the size of the cap and the difference in voltage rating.
    Electrolytic capacitors' acceptable leakage rate is based on both their uF and voltage rating. As voltage rating increases, acceptable leakage rate increases. As uF rating increases, acceptable leakage rate increases.
    Also, the higher the voltage rating, the greater the thickness of dielectric between the plates is required. Since the dielectric thickness increases, the plate area must be increased to compensate. Since the plate area increases, the parasitic inductance and resistance will also increase.
    While these parasitics will have a relatively small consequence at low frequencies, they really come into play at higher frequencies. The larger the cap size/voltage rating, the greater the parasitics.
    A size 0805 100pF 50v multilayer ceramic cap might measure that at DC frequencies (< 20MHz), but at 500MHz, the effective capacitance can triple due to the parasitics.
  3. mahela007
    Jul 25, 2008
    45
    I understand how capacitors work but I didn't understand that statement.. could you explain what the plate area must increase?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. mahela007
    Jul 25, 2008
    45
    ah ok.. I get it now. Thanks.
    C= A\epsilon / d
    as D increases, A must increase to keep capacitance constant.
