Capacitor Basic
Discussion in 'General Electronics Chat' started by eknow, Jan 30, 2007.
  1. eknow
    Jan 30, 2007
    Hi.. struggling with basics:confused:
    A capacitor stores charge.. right.. so if I charge a capcitor to some high voltage and then if sb holds it accidentally would he/she get a slight shock from the charge present in the capacitor..
  2. n9352527
    Oct 14, 2005
    1,198
    Yes.
    567890
  3. SANJ
    Jan 27, 2007
    OF COURSE.WHEN SB HOLDS A CHARGED CAPACITOR, THE STORED VOLTAGE IN IT GETS DISCHARGED THROUGH THE BODY OF THE PERSON WHO HOLDS IT. IT IS THEREFORE TAKEN AS AN SAFETY PRECAUTION TO DISCHARGE AN CAPACITOR BEFORE DE-SOLDERING IT.
  4. Salgat
    Dec 23, 2006
    215
    Please don't do all caps.
  5. Mazilla
    Jan 31, 2007
    If you accidentally charge the capacitor by some high voltage and sb hands this one he/she becomes very happy :eek: :eek: :eek: .
    note that capcitor is charged better throught a diode.
    do the next:
    Code ( (Unknown Language)):
    1.
    2.                that's diode
    3.    <----------|<|---------------
    4.                                 | +
    5.                                ---
    6.    ~240                        ---    <-- that's cap. (not less than 10uF)
    7.                                 |
    8.    <-----------------------------
    9.
    10.
    To avoid short circuit in AC line use the resistor in serial with diode.
    Capasitor will be charged up to 240 * sqrt(2) = 340 V. It should be enough to affect the result.
    I recommend to use ampermetre to monitor the current value through victim of your experements (not less than 0.1 amps).
    P.S.: plz don't do this
  6. eknow
    Jan 30, 2007
    thanks...
    340V is the rms value right?
  7. nanobyte
    May 26, 2004
    118
    What value of resistor should be used in series with the diode? How would you determine the right value?
  8. kubeek
    Sep 20, 2005
    4,688
    806
    No, the 340 is the peak value, because there is no discharging between the cycles.
