Capacitor as current limiter
Discussion in 'General Electronics Chat' started by xodbox, May 31, 2012.
Thread Status:
Not open for further replies.
  1. xodbox
    May 31, 2012
    I want to limit the current through a resistor using a capacitor in series with the resistor. The resistor has 16ohm, and it will be connected to 127V AC. I will be using a 55uF capacitor, so the current through the circuit will be 2.5A. The circuit must work 24/7. Does anybody know if there is an issue with this setup?
  2. baby_1
    Member
    Jun 3, 2011
    39
    Hello
    as you tell us the current is alternative and I(RMS)=2.5?
    if you use a resistor with 16ohm value the Power dissipation=R*I^2=16*2.5*2.5=100W
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We do not support discussions on transformer-less power supplies, as they are inherently unsafe.
    You must use a transformer to provide galvanic isolation from mains power.
    The price of a transformer is a bargain compared to the cost of a funeral. Please do not attempt your idea.
    Excerpt from the ToS:
Thread Status:
