Capacitor 0.07uf 1000 volts
Discussion in 'The Projects Forum' started by tonydix, Jul 4, 2014.
  1. tonydix
    May 4, 2010
    23
    I am trying to rescue an old solarteon oscilloscope cd 1400. It uses one of these capacitors in its eht circuit. This one appears to have failed with oil on the board surrounding the capacitor. It was a can style electolytic with wires on each end.
    Any ideas about sourcing a replacement or could I consider something like the capacitor from a microwave oven ?
    Tony
  2. Dodgydave
    Jun 22, 2012
    5,167
    776
    Vishay do a wide range of caps
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    More modern systems will use a 1kV or 2kV ceramic for that task. Cap should be available from Element14 or Digikey.
  4. john_doe01
    Nov 27, 2011
    24
    could we get a pic of the part, 0.07uf seems like a weird value
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    0.068 is common value and should be fine.
    The part is an axial lead electro which sounds very old. I wouldn't sweat about getting an exact value, the original part probably had a value tolerance of 10% or worse. :)
