capacitive voltage divider
Discussion in 'Homework Help' started by kourgurpreet, Jan 26, 2011.
  1. kourgurpreet
    Jan 25, 2011
    plz help me to simulate the circuit i have attached using tina pro.during simulation it shows error message that circuit is irregular
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Your "circuit" looks to have a gap in it. Shouldn't the two capacitors be connected together? Even if this is just a resolution problem with the picture, you probably need to add a DC path from the junction of the two capacitors to ground, such as a huge value resistance like 10^12Ω.
    Many simulators will refuse to process any circuit without a DC path from every node to ground.
