So recently in my EE class, we were taught you can use capacitors in series as a voltage divider. When I thought about it, it seemed like a way better option than resistive voltage dividers, since resistor based ones are inherently lossy, and can only deliver a limited current based on the resistance of the elements you use. I read on Wikipedia that capacitive voltage dividers are current limited by the values of the capacitors. Does anyone know how to calculate this limit? I'm having trouble finding more information about it.
Why aren't capacitive voltage dividers more common? It seems like they would be a much better solution than resistive voltage dividers with almost no loss, and I'm thinking of using it in place of a linear regulator in one of my electronics projects since the output voltage doesn't need to be very exact.
