Capacitive Proximity Sensor
KCHARROIS
Joined Jun 29, 2012
311
So I'm looking into making a capacitive proximity sensor like the picture below. I want to be able to detect the distance of about 10 cm, I have seen a video and I know you can do this, so my question is when it comes to design, how should I design the sensor pad? I dont want to use IC's.
thatoneguy
Joined Feb 19, 2009
6,359
Here is how it works. Laid out in block diagrams as well as math.
There are touch sensor ICs with TTL outputs that can drive transistors, no special magic to use, connect power and ground, put wire on touch input, when it is touched, supply voltage is at output, otherwise output is low.
If you read through that app note, you can also build one using discrete components, but false triggers are a problem.
Jaguarjoe
Joined Apr 7, 2010
767
A touch sensor won't help if the OP wants a 10cm range.
I built a theremin years ago using Panasonic analog optical sensors, it worked well and might have had the 10cm range OP wants. Google "Theremin" and you'll see many different ways to detect hands at a distance, the majority being RF.
Google Bob Moog of synthesizer fame. His last efforts were Theremin manufacturing. After seeing his synthesizer endeavors get chewed up and spit out he backed away and did the Theremin thing. He was very smart and very nice, normally two mutually exclusive traits. The good always die young :(
KCHARROIS
Joined Jun 29, 2012
311
Well see I know you can use capacitive proximity sensors because of the electrical field *fringe field I believe. When your hand gets closer the fringe field changes there for capacitance changes.
Jaguarjoe
Joined Apr 7, 2010
767
Motorola made an "e field" sensor which may have done 10cm. I have an evaluation board from Motorola for it, I'll send it to you for the cost of postage. Lemme know.
thatoneguy
Joined Feb 19, 2009
6,359
That won't work well without an IC. The concept is the same as touch sensing, a very high frequency oscillator, detect changes in oscillator frequency due to capacitance change, look at "PLL".
KCHARROIS
Joined Jun 29, 2012
311
Thanks for the replies and ideas the theremin idea seems interesting but I would need 4 different sensor withing a couple of inches from each other so I believe they would interfeer with each other.
thatoneguy
Joined Feb 19, 2009
6,359
Having the sensors closer to each other than the sensing distance is possible, but requires more processing (analog or digital) to find the "pickup" that has the greatest variation.
Jaguarjoe
Joined Apr 7, 2010
767
I don't recall the Panasonic sensor part #. They are cheap and simple to use. Toy robot builders use them for collision avoidance. I bought mine from Maximum Robotics. They had more than the 10cm range you require, probably 20.
Maybe these will give you an idea. I'm sure you could roll your own without IC's but probably not for $35. This is NOT where I bought my Panasonic parts from:
http://www.maxbotix.com/Ultrasonic_..._Sensors.htm?gclid=CKv7rcHaqbUCFUQw4AodaVMASQ
Back in the day I made ultrasonic sewer level monitors. To compensate for the dead zone close to the sensor, I mounted the sensor horizontally about 12" away from the face of a first surface mirror mounted at a 45 degree angle. This allowed the sensor to respond to water level all the way up to sensor housing itself. Pretty cool eh?
KCHARROIS
Joined Jun 29, 2012
311
Back to theremin, the antenna for this theremin is pretty big but I'd like to be the size of a coin. How much of an effect will it have?
ErnieM
Joined Apr 24, 2011
8,377
I once was working on a projected capacitance sensor, I was looking to detect water inside a tank with no openings, sense it thru the tank by change in capacitance of a sensor pressed up against the side. I was able to reliably sense water about half an inch from my sensor. You would need to experiment and refine the sensor to suit your needs.
Here are the two most informative posts:
http://forum.allaboutcircuits.com/showpost.php?p=405600&postcount=30
http://forum.allaboutcircuits.com/showpost.php?p=405868&postcount=33
