Capacitive and Inductive Impedance
Discussion in 'General Electronics Chat' started by Abhinavrajan, Aug 8, 2016.
  1. Abhinavrajan
    Aug 7, 2016
    77
    In a circuit with Capacitance and Inductance with an AC source, I see that when we calculate the value for the impedance of the capacitor and Inductor
    there is a complex component "j".
    What is the complex term and why is the complex term "j" included in the expression ?
  2. nsaspook
    Aug 27, 2009
    3,011
    2,356
  3. crutschow
    Mar 14, 2008
    13,482
    3,369
    The j is the imaginary part of the complex impedance number which represents the L and C reactances.
    It allows relatively easy computation of the impedances and phase shift in RLC circuits.
    Read this for more info.
    Abhinavrajan likes this.
  4. DickCappels
    Aug 21, 2008
    2,766
    667
    In non-electronic math instead of j, i is used for this because in electronics, i was already in common use to denote current.
  5. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    Another view is that the 'j' operator shows that the impedance is such that the current through the element is out of phase with the voltage across the element.
    For a resistor, the current is in phase with the voltage, but for caps and inductors it is out of phase by 90 degrees.
    Other representations;
    0-1/jwC a complex number
    0+jw*L a complex number
    (0,1/wC) a vector
    (0,wL) a vector
    1/wC@90 degrees current leading the voltage
    wL@90 degrees current lagging the voltage
    Note all these assume sinusoidal waveshapes only.
    There are ways around that, but that's another story for later :)
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Think of j as an operator, just like + and -.
    1)
    If we have two DC voltage sources V1 and V2, the sum of the voltages is V1 + V2.
    2)
    Here the sum is V1 + (-)V2. That is, the operator (-) indicates that the voltage source is flipped by 180°.
    3)
    We can do the same with AC voltages.
    The total voltage is
    Vtotal = V.cos(ωt) + V.sin(ωt)
    One way of solving this is to recognize that a sin wave is a cosine wave delayed by 90° or π/2.
    Vtotal = Vcos(ωt) + Vcos(ωt - π/2)
    We use the j-operator to represent a phase shift of -π/2.
    Thus
    Vtotal = V.cos(ωt) + j.V.cos(ωt )
    4)
    When applied to inductors and capacitors in AC circuit analysis, we use the impedance of the components.
    ZR = R
    ZL = jωL
    ZC = 1/jωC
    The total impedance of R1 and L1 in series is
    Ztotal = ZR + ZL = R1 + jωL1
    The total impedance of R2 and C2 in series is
    Ztotal = ZR + ZC = R2 + 1/jωC2 = R2 - j/ωC2
    Thus observe that the current in L will lag the applied voltage by 90° whereas the current in C will lead the voltage by 90°.
    Remember this phrase:
    ELI the ICE man
    This will help you to recall that the voltage (or EMF) leads the current (I) in an inductor (L) whereas
    the current (I) leads the voltage (E) in a capacitor (C).
    Abhinavrajan, DGElder and cmartinez like this.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    Let us combine R, L and C altogether in series:
    Ztotal = ZR + ZL + ZC = R + jωL + 1/jωC = R + jωL - j/ωC
    At decreasing values of ω, the capacitance term dominates, and the current leads by π/2.
    At increasing values of ω, the inductance term dominates and the current lags by π/2.
    Thus Ztotal has a minimum impedance at a certain ω. At what value of ω is Ztotal at the minimum?
    The phase shift from L and C cancel at a certain ω.
    At what value of ω is the phase shift zero?
    Is this a band-pass filter or a notch filter?
  8. Abhinavrajan
    Aug 7, 2016
    77
    Understood. But how does the complex term help while solving some circuit problems. Suppose I have an AC circuit with R,L,C having 20k , 20mH and 0.1uF respectively and I need to find the total impedance of the AC circuit, How am I supposed to solve with the complex term involved. So, the final answer will also have a complex term,right ?
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    Abhinavrajan and cmartinez like this.
