Capacitance meter of 40 milli farad range
Discussion in 'General Electronics Chat' started by vks_foe, Nov 29, 2013.
  1. vks_foe
    Thread Starter Active Member
    Jan 11, 2009
    55
    5
    Can somebody pls suggest a handheld meter which can measure capacitance upto 40 milli farad? Also, is there any website where we can compare the meters (DMM, portable oscilloscope etc) by specs? It is very difficult to choose a meter even amongst the meters of one brand.
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    40 millifarads is an unusually large value of capacitance, not often encountered in electronics work. Thus, most handheld DMMs will not cover this range. You'll probably have better luck with a dedicated LCR meter, or a bench DMM. Or, with this large value capacitance, it wouldn't bee too hard to estimate the capacitance by measuring charge time via a resistor and power supply, or current source.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    The vast majority of meters max out at 20 mF.
    This one goes up to 200 mF:
    http://www.home.agilent.com/en/pd-1...acitance-meter?nid=-34196.920241&cc=US&lc=eng
  4. k7elp60
    Nov 4, 2008
    479
    69
    Another solution would be to take a value in uF, measure it and then put it in series with the larger value, measure the total capacitance and then calculate what the larger value is.
  5. vks_foe
    Jan 11, 2009
    55
    5
    Its a nice idea.. in theory.. Can there be any practical issues which may bring in any error ??
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
  7. PackratKing
    Jul 13, 2008
    850
    216
    Someone is not considering their scientific notation here...
    milli-farad = 1/1000 farad
    microfarad, 1/1,000,000 -- is the standard measure for a DMM... either that or it's me that ain't paying attention :D
  8. k7elp60
    Nov 4, 2008
    479
    69
    The only thing I can think of is the accuracy of the capacitance meter. I currently have a BK Precision LCR meter that measures up to 2000uF. It is model 875A(I have had over 10 years)I have used it to measure low value of capacitors in the pF range, by putting capacitors in parallel, and measuring inductors of low value by putting inductors in series with a higher known value.
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    Agilent is not Chinese, it's a division of Hewlett packard and the range is what it says it is.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    I know what the specs mean and so does Agilent. It is what it says it is.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Sorry I should have posted more clearly. My point was that if checking specs of products on ebay etc, where they have "Chinglish" specs etc to be aware that they can sometimes use "mF" to mean microfarad.
    I did not really expect the Agilent product to be specced in Chinglish, it was a general warning about "mF". :)
