capacitance measurement
Discussion in 'General Electronics Chat' started by yogesh5387, Mar 13, 2015.
  1. yogesh5387
    Mar 13, 2015
    7
    I am interested in measuring a Small change in Capacitance for instance nF change..
    Can anyone suggest circuit ?
  2. MCU88
    Member
    Mar 12, 2015
    360
    35
    Hello ...
    It is uninspiring to design such an circuit given that you can buy an professional capacitance meter on eBay for something like USD50 inc ship. This meter will measure caps in the pF range. Most likely better than 1pF with accuracy of +/- 1%
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    1) Please clarify whether you want to detect a change in capacitance, for example, to operate a switch, or do you want to measure the capacitance of various capacitors?
    2) Are you familiar with microcontrollers, or do you want a completely analog solution?
    John
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    A 555 putting out known pulse width pulses, through a resistor to charge the cap, makes an integrator, voltage higher for more capacitance see "integrator"
  5. yogesh5387
    Mar 13, 2015
    7
    thanks for your reply!!
    I am familiar with Arduino microcontroller ..I have tried 555 timer circuit is not so fast for measuring the capacitance...I am open to any circuit but i want to measure the change in capacitance in nf
  6. yogesh5387
    Mar 13, 2015
    7
    555 timer is measuring frequency but it is very slow in updating frequency .....I am interested to measure capacitance with sampling rate of 2 KHZ
  7. yogesh5387
    Mar 13, 2015
    7
    I want to measure change in capacitance in nf ...The measured capacitance should be very fast with sampling rate of 2khz minimum
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    hot measuring the 555 frequency,, just measuring the voltage across the cap. a method used here to measure liquid levels in chemical tanks.
  9. wayneh
    Sep 9, 2010
    12,394
    3,246
    Another approach is to make the capacitor part of the timing components for an oscillator and then measure the frequency. But the quick and easy approach is to buy a meter as already suggested.
  10. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Your question needs more work. Is the capacitor in a circuit or on a shelf? Do you want the value displayed in a readout or can it be a change in the pitch of an audio tone? In other words, what are you trying to do, and why?
    ak
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Then make the 555 astable oscillator run at a nominal 2kHz (or higher) and then use the Arduino to measure the period of the square wave (time between two successive up-edges, for example). It is trivial to compute the freq by taking the reciprocal of the period.
  12. Alec_t
    Sep 17, 2013
    5,979
    1,138
    I'm curious as to what you have that exhibits a 1nF (at least) change of capacitance?
    Do you want to know the amount of the change, or simply detect that it has changed?
    How will you signal/indicate the change?
  13. yogesh5387
    Mar 13, 2015
    7
    I would like to see the change of the capacitance for instance (fF) ..I am really sorry for saying nF in previous comments ..
    My intention is to see the capacitance change in (fF)..
    thanks in advance!!
  14. jpanhalt
    Jan 18, 2008
    5,699
    909
    That is an entirely different problem. It won't be easy. May we ask why femtofarads?
    John
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    It would have been better if you had kept it to nF or pF.
    fF?
    Forget it. That is beyond the expertise of most people here on AAC and anywhere else.
    wayneh likes this.
  16. jpanhalt
    Jan 18, 2008
    5,699
    909
  17. alfacliff
    Dec 13, 2013
    2,449
    428
    unless your able to spend very large amounts of money and effort, it will be like the 8 digit resisgtance meters, the last several digits just jumoing around. air currents will affect femto farad measurements. look up body capacitance too. anything conductive moving even a little in the area will mess up your measurements.
  18. crutschow
    Mar 14, 2008
    13,508
    3,385
    What is the capacitor you are trying to measure?
  19. yogesh5387
    Mar 13, 2015
    7
    I have PCAP from Acam but they have limitations the updating rate is only 600Hz ..I would like to have 2KHZ ..
    I have also spoke with the company (ACam )they are asking to write code for making it to 2KHZ updation but that not so easy it has lot parameters to load it ..
    So can anyone done simple or complex setup with minimum of 2khz update rate ....
  20. jpanhalt
    Jan 18, 2008
    5,699
    909
